🙁Euro tail light--Season 2; The plot so far...
The Curt CS56196 2 to 3 wire converter module wasn't the final solution. As installed (no extra components like diodes/load resistors) well give you the separate turn signal & brake lights without any issues, but when you combine the brakes and a turn signal you get four 'normal' flashes and then turn signals go into 2x mode (twice as fast)--brake lights are fine. Since the turn signal is a bulb in both the US & European versions (about 1.8A draw per bulb) the loading should be about the same on turns, but the US would also run the opposite bulb for the brake, where as the Euro brakes (LED) draw 375mA per unit (750mA total). So I added a 14 ohm load on the brake line to add 1 amp to the total brake draw--talk about a light show; turn signals normal, brake signal normal but turn signal & brake will flash the brake lights as turn signals and the turn signal itself will flip to the opposite side (ie: right turn will become left turn with brake applied).
Also tried disconnecting the brake wire to the tail lights (both with & without load resistor) to see if just the turn signals would work without the 2x flash rate (idea being if they did work, I would tap off the signal from the centre mounted brake LED)--nope--left turn was fine, the right would flash 4 times then double speed.
What we have learned today:
1) A 24 inch piece of weed whip line, straighted-up with a heat gun make a good fish line for the tail light conduits.
2) Connector (chassis side) is a Molex MX150 connector (PN 033471-0406).
3) The socket connector is PN 033012-2002 (for the new brake wire).
4) In spite of the Molex installation guide, you can extract the barrier plug where the brake wire goes.
5) The pin extractor (Molex 63813-1500) is recommended for the above.
6) OptiSeal butt splices come in very handy.
7) 50mL of Tanqueray gin mixed with 6 oz. diet ginger ale (x2) helps puts things in perspective.
