One thing I noticed, which I think is an oversight, is when using the windshield washers the wipers wipe the glass before the washer fluid is actually sprayed, which actually makes the windshield clarity worse if bug splatter is involved and it isn't raining. It isn't good for the wiper blade rubber pieces either.
I’m either an idiot, or am having a senior Moment
Let's hope it is not BOTH! 🙂
Glad we could help.
Unless someone knows of a way to test this.... Next person to have their fuel door stuck closed, can you please try the above proceedure to see if putting car in "service mode" will allow you open the door in an emergency?
When you tap the turn signal stalk, i.e., push it down gently then release it, the turn signal flashes 3 times. Great for lane changes. 2019 Essence S & S with DC 1 & 2.
And my '13 VW allowed me to choose 3, 4, or 5 flashes in the vehicle settings menu.I think every GM car for the last 15 years or more has done that 🙂
I recently found out the 'mic' button also allows voice commands, including searching for genres/artists/albums.confirmed FLAC music files can be played from a USB flash drive
I thought it was to clear a flooded engine.Not sure if it was mentioned before, but if you hold the accelerator to the floor while pressing the start button, it will crank over but not start. As soon as you let go of the accelerator pedal then it will start. This is useful for priming the engine after changing the oil.
