Space Saver Spare Tire Size TourX Essence
Just wanted to share my spare setup. Going on a long road trip tomorrow (through Colorado, I should be able to test out this AWD and get some great pics along the way).
Picked up a spare from a 06 Cadillac DTS from a junkyard about 30 minutes away. When I test fit it, I immediately noticed that it doesn't sit evenly on the base of the well (duh), so I had to get creative. I cut the bottom part of the stock foam storage thing with a multi-tool and a bread knife around the same level of the flat part that the sub sits in.
The bottom of this piece is contoured to level out the bottom of the spare tire well, so when cut, it's a nice flat surface for the spare to sit on. I then wrapped the spare in a fabric bag that came with my table saw. It's been sitting in my basement for a year, so it's about time I found a use for it. I picked up a jack from Lowe's, and already have a breaker bar and socket set in my tool kit (which is strapped in the hatch where the first aid and triangles are supposed to go. As you can see in the pic, the sealant fits pretty nicely in there. Not pictured is the portable pump, jumper cables, jack, and a few other small tools that I wrapped in old socks and tossed in there. I'm pretty happy with this setup, and if it turns out that I get unlucky and end up with the water in the spare tire well issue, the wheel and everything else is still well elevated by the foam.
The only hurdle I had to jump was getting the plastic piece to screw back in. The sub on top of the spare was just a little bit too high, but the flat part of the plastic piece pops right off and that provided enough relief to get everything screwed down. I'm pretty happy with out this turned out.
Can anyone tell me what the stud pattern is for the GS, please? So far as I know the GS and the Commodore VXR are basically the same spec particularly around the 20" rims and the Brembo brakes on the front axles.
I thought all the Opel based Commodores had the same stud pattern with a PCD of 115 mm. However I have been told the VXR has a PCD of 120, with data from one after market rim dealer confirming 120. Yet all the data I can find otherwise says the PCD is 115.
I'm pretty sure the GS and VXR will be the same. Any information will be appreciated. Thanks.
The GS was never optioned with the same 20" wheels that are on the Insignia/Commodore VXR. Only the Insignia/Commodore VXR have a 5x120 lug pattern. The GS lug pattern is 5x115 and has 19" wheels.
Thanks for that info. For some reason I though the GS has the 20' rims. The style is exactly the same for both the GS and the VXR. Perhaps that's why I though they we both 20".
There is plenty of confusion out there as several wheel sites quote the 5 X 115 for the VXR
Here you go mate, now Im curious the accessories you get ie air compressor etc..
I swear the Holden part numbers for the foam were posted but I can't find them in the search. Do you have the part numbers for the foam pieces particularly the piece on the left hand side that holds the jack and wrench?
I'm back on this project, as I've been told the used spare wheel I have with a 5x115mm bolt pattern does not fit. I pulled a rear-wheel yesterday and tested the spare-wheel fitment. No go, seems like the lug bolts on the spare wheel measure to 115 mm, but the lug bolts on the vehicle measure to a bit less (110mm?). Is that even possible that our 2019 TourX could have a wheel bolt pattern less than (5x)115mm? Certainly, my measurements could have been inaccurate to nearest mm, but the spare (used) wheel would not fit on the vehicle. Planning on taking more "back-road" trips and would like to have a spare.
The spare you have is smaller than the OE tire, correct?
I have a spare that fits in the spare well (tight fit) but the circumstance is smaller than the OE wheel.
Yes, the spare tire is a 125/70/17, the spare wheel is a 17x4. I don't know why the wheel won't line up with the lug bolts (studs). Or is the used spare wheel, the wrong one or damaged? Or maybe I can't measure accurately enough? It's always somethingoriginal and spare 2.webp
