93ParkAveUltra
- Feb 3, 2024
- 1993 Park Avenue Ultra
So we replaced the valve covers as well as the oil pan gasket due to a massive oil leak. At the same time I did replace both belts as the alternator had to come off anyways. It did not have these running issues beforehand. I disconnected the battery before doing all this.Can you show me closer on the belt like directly top down and also the ribs up close.
And your battery … unacceptable. I’ll post why you need to fix that
can you find the tensioner adjustment marks on both tensioners, but first start with the one for the supercharger belt.So we replaced the valve covers as well as the oil pan gasket due to a massive oil leak. At the same time I did replace both belts as the alternator had to come off anyways. It did not have these running issues beforehand. I disconnected the battery before doing all this.
What exactly am I looking for? I assumed they were self tensioning and did not look for any marks when I installed the belts. I'll address the battery tomorrow. I have an oreillys up the road. The video would be too large to upload but I can Rev it all the way out in neutral and park with seemingly no issues. I drove it again and it does have a rough idle and misfire below 2k.can you find the tensioner adjustment marks on both tensioners, but first start with the one for the supercharger belt.
I changed both the plugs and wires as I did the valve covers. You can hear the supercharger and engine both make noise as if they're bouncing off of a Rev limiter. No lights flashing. It shudders when it does this. Not violently bucking.View attachment 45855
Did you touch the ignition wires or the spark plugs in any of your work on it? to me it sounds ignition possibly. Can you tell me how it goes about stopping to rev past 3k, does it chop, shake, flash the engine light, etc.
The tension marks should be on the round part of the tensioner (lower one) i sent you a diagram above in my previous messages but i screenshotted the part that shows where it is here in this message
They are self tensioning, but they only work in a short range of belt sizes, and if they are on the "stops" they wont do their job.
what firing order did you put the wires on? And can you show me a picture of the plugs you removed and the current layout of your wires/plugs (so a picture of your engine bay basically)I changed both the plugs and wires as I did the valve covers. You can hear the supercharger and engine both make noise as if they're bouncing off of a Rev limiter. No lights flashing. It shudders when it does this. Not violently bucking.
I put them on exactly as they came off. The ones I bought were labeled. I threw the spark plugs away. But i can get you a picture in the morning!what firing order did you put the wires on? And can you show me a picture of the plugs you removed and the current layout of your wires/plugs (so a picture of your engine bay basically)
Also I cant be sure of it from the photos but you appear to have cylinder 6 and 2 wires swapped on the back of the engine. but i cant see what the wires do where they travel under the snout/engine cover. so re-laying the wires to be alongside eachother on the wire holders from front to back is a helpful thing to do to ensure they are
The wires are NGK they all came labeled. I did them one by one but I will double check to verify. I didn't take the snout off when I did the wires so I just pushed them through the best that I could. I didn't know that crossing them would mess it up that bad. I can go through and redo those. The dipstick handle was glued together when I bought it. It snapped today when I bumped it. I have another in the mail. The egr wires got chewed before I bought it. I drove it 6 hours home from Tennessee like that and it was smooth as butter. I also replaced the pcv valve trying to chase this issue, but no improvement. It's always had a little miss at idle, but everything I've done to tune it up and clean up the oil leaks made it worse.View attachment 45865
