Joining the rear diff club
How many quarts of gear lube are needed do a fluid change?
One quart will do the job for both the PTU and rear diff.
It's actually closer to like 0.83 quarts, you fill until the fluid starts dribbling out the fill hole, you'll have a small amount left over.
For reference I lik the video again fo the groan noise coming from the diff.
https://www.youtube.com/watch?v=aFhfgxqQUxU
Per factory service manual the troubleshooting states:
First change the fluid, if the noise persists replace the carrier.
The lube arrived today. Does the pinion seal replacement require the fluid to be replaced? Anyone been having leaking pinion seals?
Just wanted to add my experience to the thread for others. Had my rear diff fluid changed at about 80k miles on a 2018 Tour X (red needle). The local shop used valvoline 75w90 full syn. The next day the groaning and noise from the rear end started...low speed turns when starting from a stop primarily. Had to drive it for a few weeks just due to schedule but had them drain the valvoline and replace with the GM recommended fluid. Noise was gone instantly. No new information here but confirming what others have said/encountered.
Mine just started leaking around 57000 miles
Yes, I have oil up on the frame above the pinion seal so I will be replacing mine when I do the lube change. Groan might be from lower level. Looks like I will need to pivot the sway bar down to access the fill plug. Also I hate those two piece driveshafts with the bearing in the middle. Might just take it in to my mechanic. I still don’t have my summer only car running and summer cruise night season is almost over.
I have an appointment at the dealer this week to change the trans, PTU and diff fluids including the seal and a couple other things. Carfax says a Valvoline quick lube place changed the PTU and rear diff at 49000 so I'm sure it's got the wrong fluid. No noise though.
I use a 10mm Allen socket. I remove the hex from the socket, then use a crescent wrench to turn the Allen hex key.
As far as differential lube, I just tried the Valvoline equivalent. Now I know what people are talking about with the moaning. Also, very harsh going from throttle to coast to throttle. Put the nice clean 6k GM product back in before work next morning. All better. I guess it’s worth what it costs. I don’t know what additive pack GM uses….now I’m wondering if the Delco lube is masking an issue the Valvoline exposed, or if the Valvoline just doesn’t cut it. Hoping the former.
You might want to try some----
LIQUI MOLY Gear Oil (GL4) SAE 85W-90 | 1 L | Gear oil |​
---https://www.amazon.com/gp/product/B004FPP362/?ref_=pe_125775000_1044873430_AGH3Col0502IMG_rtpb_2p_2_lm&pd_rd_wg=42s38&pd_rd_w=UUo6z&pf_rd_p=f1e7cce8-f7fa-4eb4-9109-f0143f124a1a&pd_rd_r=47454cda-2be0-4fa9-9383-42c5602fb6b0&content-id=amzn1.sym.f1e7cce8-f7fa-4eb4-9109-f0143f124a1a
Update on mine. Wasn't the pinion seal leaking and slinging gear oil everywhere, rather the RR axle seal. $400 fix at the dealer. Anyone else have axle seals replaced?
One of my axle seals has been compromised for a long time (not sure when it started, car has 94k miles now) but only weeps slowly so I plan to leave it alone and keep checking every 3 months unless it starts to get worse. No detectable drop in diff oil level in 1 year.
Did they have to drain the diff to replace the seal, do you know?
I wanted the trans, PTU and diff fluids changed so it was getting done regardless. I would imagine yes the fluid should be drained to pull the axle, but not sure. There are 3 bolts and 1 nut on the invoice that get replaced along with the seal.
Thanks to everyone who's contributed to this thread. Adding one more data point:
2018 TourX, 80000 miles. The rear differential had been weeping fluid for a while, and instead of an expensive fix, we topped it off a couple times with OEM fluid.
A couple thousand miles ago it began groaning, and eventually got quite loud. I finally took it in to a shop and -- per advice found here -- I asked them to flush it and refill with new OEM fluid. The sound disappeared, and after a week of driving, we're still groan-free.
Will report back if the diff acts up again.
Per FSM:
If groan found
1. replace fluid
2. if groan continues replace the unit
Follow up: Had the pinion seal replace and lube drained and replaced with the recommended Delco 10-4034 (88862624) and the groan is gone.
Hello all. I don't think I have posted ever. I just found this thread recently. My 2019 Buick Regal TourX had the differential groan and needed a replacement. Bearings were totally shot. The worst part was that the dealer was not willing to help with a replacement. The back and forth over supposed "part availability" was 2 months. I felt pretty stupid when I could log on to GM parts and find it myself. A separate transmission repair shop was willing to fix it an work with my warranty company. The shop had to wait for the warranty company to inspect and "ok" the repair. All-in on the second shop took 2 weeks between the inspection, ordering parts, and repairing.
Is the failure common? (mine was bearings)
Hi all!
I am driving Opel Insignia B Sports Tourer 2017 which is the same as Regal Tourx.
I have read a lot about rear diff oil change and hydraulic fluid change and according the service manual I am under the impression that the clutch system bleed is extremely important after replacement of the hydraulic fluid.
When I drained the old hydraulic fluid it was about 340ml which is the right amount regarding the service manual.
But I was able to pour only about 290ml and it started to leak drom the filling hole.
This makes me think that after this bleeding procedure I will be able to top up some more fluid up to 340ml.
The problem is that I am unable to run the bleeding procedure over GDS2. It shows me "Service not supported"
Does someone have some experience with the bleeding of the clutch?
