The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
One quart will do the job for both the PTU and rear diff.How many quarts of gear lube are needed do a fluid change?
Mine just started leaking around 57000 milesThe lube arrived today. Does the pinion seal replacement require the fluid to be replaced? Anyone been having leaking pinion seals?
Yes, I have oil up on the frame above the pinion seal so I will be replacing mine when I do the lube change. Groan might be from lower level. Looks like I will need to pivot the sway bar down to access the fill plug. Also I hate those two piece driveshafts with the bearing in the middle. Might just take it in to my mechanic. I still don’t have my summer only car running and summer cruise night season is almost over.Mine just started leaking around 57000 miles
I have an appointment at the dealer this week to change the trans, PTU and diff fluids including the seal and a couple other things. Carfax says a Valvoline quick lube place changed the PTU and rear diff at 49000 so I'm sure it's got the wrong fluid. No noise though.Yes, I have oil up on the frame above the pinion seal so I will be replacing mine when I do the lube change. Groan might be from lower level. Looks like I will need to pivot the sway bar down to access the fill plug. Also I hate those two piece driveshafts with the bearing in the middle. Might just take it in to my mechanic. I still don’t have my summer only car running and summer cruise night season is almost over.
I use a 10mm Allen socket. I remove the hex from the socket, then use a crescent wrench to turn the Allen hex key.Yes, I have oil up on the frame above the pinion seal so I will be replacing mine when I do the lube change. Groan might be from lower level. Looks like I will need to pivot the sway bar down to access the fill plug. Also I hate those two piece driveshafts with the bearing in the middle. Might just take it in to my mechanic. I still don’t have my summer only car running and summer cruise night season is almost over.
Update on mine. Wasn't the pinion seal leaking and slinging gear oil everywhere, rather the RR axle seal. $400 fix at the dealer. Anyone else have axle seals replaced?I have an appointment at the dealer this week to change the trans, PTU and diff fluids including the seal and a couple other things. Carfax says a Valvoline quick lube place changed the PTU and rear diff at 49000 so I'm sure it's got the wrong fluid. No noise though.
One of my axle seals has been compromised for a long time (not sure when it started, car has 94k miles now) but only weeps slowly so I plan to leave it alone and keep checking every 3 months unless it starts to get worse. No detectable drop in diff oil level in 1 year.Update on mine. Wasn't the pinion seal leaking and slinging gear oil everywhere, rather the RR axle seal. $400 fix at the dealer. Anyone else have axle seals replaced?
I wanted the trans, PTU and diff fluids changed so it was getting done regardless. I would imagine yes the fluid should be drained to pull the axle, but not sure. There are 3 bolts and 1 nut on the invoice that get replaced along with the seal.One of my axle seals has been compromised for a long time (not sure when it started, car has 94k miles now) but only weeps slowly so I plan to leave it alone and keep checking every 3 months unless it starts to get worse. No detectable drop in diff oil level in 1 year.
Did they have to drain the diff to replace the seal, do you know?
Follow up: Had the pinion seal replace and lube drained and replaced with the recommended Delco 10-4034 (88862624) and the groan is gone.Yes, I have oil up on the frame above the pinion seal so I will be replacing mine when I do the lube change. Groan might be from lower level. Looks like I will need to pivot the sway bar down to access the fill plug. Also I hate those two piece driveshafts with the bearing in the middle. Might just take it in to my mechanic. I still don’t have my summer only car running and summer cruise night season is almost over.
