buickwagon
- May 6, 2011
- Muskoka Ontario
- 95 Buick RMW, 01 Regal
Where is the PCM grounded or which wire is it?
I'm out of town today, and don't have my manual with me to check. I'll try to track that down for you tomorow.
The VSS is fine, as a brand new one was put in and it didnt change any of the symptons. The fact that sometimes it works fine and sometimes not, is really frustrating. I have replaced the wiring directly from the PCM to the VSS and theres no change... I will try connceting a test light this evening. Will I need the car running or the key in the on position at least?
Key on, engine off. I'm not surprised that replacing the sensor didn't work. The problem with engine codes is that they represent what the computer thinks is the problem. All too often there are other things that can mimic similar symptoms. When you have multiple codes and other symptoms like this, it's usually a matter of analyzing the systems and looking for the common denominator.
In your case, having replaced the wires to the sensor pretty much confirms the problem is elsewhere -- either in the PCM or the wires to it. And IIRC, you replaced the PCM with a known good unit already, correct? The test I suggested will hopefully further isolate the problem to either the ground circuit or the power circuit.
Out of curiosity, why did you replace the PCM? Was this part of your diagnostics, or something related to your modifications (torque converter, etc.)?
