2.0T LTG Performance Mods
DoUSail2
You cannot tell me you won't see any performance change by not changing the intake after installing a larger turbo, that is just not true. You are just going to leave some horsepower on the table that could have easily been had.
Also changing stock intake over to a CAI on the stock engine provides such a small improvement that a tune is not even worth it. In fact the CIA is not even worth it unless it is going along with other supporting mods because the OEM airbox is designed to flow enough air for the stock engine.
BoostedRegal2.0
119
You are correct. What I should have said is if the intake and exhaust are maxed out in air flow volume, installing a larger turbo or higher flowing heads won't give the engine any more power without installing a higher flowing intake and exhaust.
Rhetoric
164
MPLS
2018 TourX
We already have a ‘cold air intake’ anyway. There is a tube that runs from the front of the car into the air box.
Most ‘cold air intakes’ are just a big dumb filter pulling hot air from the engine bay. As such, they should be called hot air intakes.
L J
59
Regal TourX
Since air flow in and out of the engine is limited by the intake and exhaust, then according to you a tune is needed. Thanks for confirming what I have been saying all along. :thumpsup:
You can add a bigger turbo and higher flowing heads, but if you don't improve the airflow of the intake and exhaust the engine won't make any more power. This is why people install a higher flowing intake and exhaust then tune the engine. :driving:
I said and not or ...but you can rationalize being right any way you want.
Buschb
22
Tour X
Modern fuel systems will compensate for any airflow differences in airbox or filter. Not like in old days when carbjets needed to be altered for increased airflow, to get correct air mixture.
an O2 sensor is going to take the place of the MAF?
Jwmsa17
TourX
On my WRX, GTI and GLI, all 2.0 Direct Injection Turbos the intake was the last place to make a mod unless you wanted to have to tune it immediately. The biggest gains came from changing the charge pipe (intake side between turbo or intercooler and throttle body) and the down pipe (connects the turbo to the catalytic converter). The LTG has mods for the down pipe but I've only seen them for the RWD platform vehicles.
Buschb
22
Tour X
Yes, I assume the biggest bang for your buck would be a downpipe and tune. I'm not going that route until the car is out of warranty.
Just a guess here...If one was to swap the turbo...a fuel pump, injectors and larger intercooler would also be needed?
I have a stage 2 Forester XT, which is a very fun wagon.
gmguy83
13
2018 Regal sportback
New to the forum, and found this post. I've been experimenting with my 18 regal. so, the regal is pretty much the same as the 2016+ ltg malibu .
-I've ordered the zzp 16+ malibu catless o2 housing, which should be a direct fit, which i will confirm when i receive it. i have found no exhaust options, but the stock main pipe is 2.5" and the y-pipe in the rear is 2.25, which should be able to flow well enough for a reasonably high power level if resonator is removed and mufflers are changed/deleted ( testing exhaust sound with the center pipe unbolted and hanging, the exhaust really wasn't too loud or obnoxious).
-The 2016+malibu k&n or aem intake should bolt right up, and both have heat shields sealed against the hood, which i will confirm with the k&n soon. I know the stock airbox should flow adequately, but i've never seen filter issues with k&n other than when people don't clean or oil the properly.
-I've already installed the jacfab boost-o-lator which is a plunger modification for the stock bypass valve. very easy install with a 1/4 inch u-joint and ball head allen. didn't really feel a difference, as i doubt my butt-dyno accuracy.
-There are a few companies that offer turbo upgrades for the ltg, which should work the same in the 18+ ltg engines also, other than a lack of tuning options as of yet.
- I've also ordered a tune/tuner from IPF tuning which i will confirm if it works or not when I receive it. I contacted them and they claim it works for the 18 regal 2.0, and claimed they can do options such as deleting p0420 dtc or disabling start/stop system.
I'm hoping this all works out well, but being a gm tech, i'm sure i can rectify the situation if an issue arises with these mods.
Rhetoric
164
MPLS
2018 TourX
Lol. CAI needs a heat shield? How ironic.
Wish I would have thought up that ‘performance’ part. I’d be rolling in dough.
BoostedRegal2.0
119
Welcome to the forum gmguy. It seems like you have it covered on what mods are available for the 2.0 LTG. It will be interesting to see how much more power you can squeeze out of this motor.
According to the thread below, the stock intercooler is sufficient for a larger turbo. The stock fuel pump delivers 2,250 psi so that will sufficient also. So higher flowing injectors should be all you would need.
Buschb
22
Tour X
I have a COBB CAI (with box) on my Fozzy, my temps are pretty much the same.
I'm a whore for turbo noises, heck it sounds better than a BOV
Rhetoric
164
MPLS
2018 TourX
I just play sounds from a Pratt & Whitney J58 through my Bose system instead of music. Makes me feel supersonic, even with auto-stop on.
gmguy83
13
I hope to see some decent number with all this, IPF is claiming 287whp and 353wtq with their tune and similar mods, but im at 5000ft elevation, so i always get gyped on dyno runs. I really want the k&n for the noise too.
i dount ill be needing any fuel upgrades until it comes time for a bigger turbo though.
Rhetoric
164
MPLS
2018 TourX
Those are some solid numbers.
Do we know what the driveline components can handle? I’d hope that we’d have some wiggle room to go bigger without the need to go too deep.
gmguy83
13
Im not sure about the 8 or 9 speeds capabilities. They appear to use similar clutch packs setups as the 6 speeds, so i would assume programming to shift with higher pressures should be able to handle some decent power. Im not sure about availability for trans tuning yet though. As for the transfer case, driveline, and rear diff, hopefully I'll find out soon if they can take it.
mike69440
59
2018 TourX Essence
I'm sure the drivetrain can handle it. My car has the Halidex AWD system and the Trifecta tune hasn't caused any broken parts in 4 years of hard driving.
480Nm= 354 ft-lb is the Transmission rating. Aisin 8-Speed FWD Transaxles - Volvo, Toyota, Lexus, GM (AWF8F45) The TourX has a GKN, AWD drivetrain, Twinster AWD System, not a Halidex. I would be really pleased if the Trifecta tune can reach 350 lb-ft flywheel torque. Be serious, besides myself, how may will even add a tune, never mind boosting the motor much beyond what say a stock Camaro 2.0 LTG. I plan no mods besides a tune, maybe tires. A honest bump of say 35 HP & 45-50 lb-ft and crisping up the tranny logic is worth the cost of a tune, as long as there is no downside other than warranty risk.
Anyone interested in approaching Trifecta with a group buy letter of intent?
