2022 Buick Envision won’t start up
EnvistaBuick
2022 Buick Envision Preferred
Hello guys!
I have had this Envision that I bought from auction around 4-5 months ago. It was starting up and running/driving fine. I put a tender in the jumping tab and the ground in the strut, just to keep the battery charged. All was fine, I was turning on every week or so. But I haven’t turned it on in about 2-3 weeks, probably a month. Today I tried, it started it up but suddenly turned off. Every time I try, it starts but after 1-2 seconds it will off. Also I have notified this buzzing noise in the front (watch the video) which have been making it since I bought it. Any idea? I disconnected the battery to see if it will help but this might not be the issue.
Thanks
I'd guess the high pressure fuel pump is bad/dying. Do you have a CEL?
put a fuel pump power module in it ...veryyyyyyyy common failure, causing crank no start!!
you may even have a recall for it and would be covered!
Does anyone know how to reprogram the module? I have an Autel Scan Tool, but i think I need a laptop (i have), to buy the GM software (I dont know which one exactly), and few more things, thats why Im asking. I know recalls are free, but this is a car bought in auction so still I need to repair it, register it to put it on the road, and I cant move it now from my driveway, so I bought the module ($55) and just need to find the right procedure to reprogram it.
Appreciate any help
By the way, I have a lot of documentation from ALLDATA in case you guys need anything. I found few things about the Fuel Pump Module but not sure if there is something missed in the reprogramming part.
they dont require programming. plug and play.
Im a tech at a gm dealer. if any questions shoot me a message!! i can check if its covered as well under any policies- dm me if you want
You are going to kill me but I cant find a link/button to send you any DM even looking at your User Profile. Not sure why. Can you send me a DM?
Maybe you can't dm on this forum
.I'm new too. All good any questions just shoot them on here
Hover your mouse over the guys name on the left. A window opens up and left click on "Send direct message"
That does not appear for me, for anyone I try. It just shows FOLLOW and IGNORE. Are you on a PC or a phone?
The same for me. I was only able using phone , but not always was like this before. I don’t know if it needs to validate amount of messages or something for new users. Weird because this is the first forum I have had an issue sending PM
maybe a certain time frame has to pass in order to use it. will see guess!
