Rschmauch
- Aug 5, 2019
- 2005 Buick LaCrosse CXL
Hello there. For awhile now I’ve been dealing with possible issues with the ABS system. When I would go slow at times, I get this grinding or buzzing noise and the brake pedal gets hard to push. When the ABS and traction control warning lights come on, it doesn’t make the noise and I could then brake without any anxiety.
I have run a code scan and the code I get is a C0036 code which says “LF wheel speed sensor circuit range/performance.” I’m tempted to pull the fuse, but do I pull the main ABS fuse or all of the ABS fuses? I do want to eventually get this fixed, but I just wanted to get some input.
What could be causing this and what advice would you give? I don’t want to be struggling with this ABS issue much longer.
