Any idea where I might get one of these parts, and is it difficult to put in? I've tried searching both the part number and HMI NG 2.5 and not gotten anywhere. Would a dealer do it, or do I have to find somewhere to buy it?
I have a 2014 Regal with Intellilink, but no nav. Would that also add nav?
Every 2014+ has intellilink. You do not need to specify it like the older generations do
If you have no nav, then you have RPO IO5. The HMI part number I gave you would upgrade you to RPO IO6.
RPO IO6 is the same system you have now but with the factory nav option.
Your icon for on*NAV will change to just "Navigation" as the unit has a nav application and maps built into it.
If you use a NG2.5 HMI with IO6 (the part number I sent you), you will add
Android Auto,
CarPlay, and Navigation to your current system.
You will loose the Time Shift Radio functionality.
You will need to add a nav antenna (the blue connector)
No it is not hard. If you have ever put a radio in a car before you can handle this. It is a plug and play upgrade.
You can purchase it preprogrammed from Chris@whiteautoandmedia or you can go the DIY route and procure it yourself and have someone program it locally.
Do you know if a 2013 radio could be dropped into a 2011 with nav?
They use the same system made by Panasonic. The connectors are physically the same. However there are some differences between early and late production 2011 cars in the connector pinouts. You will probably have to shift some wires around but it shouldnt be too big of a pain.
In a 2011 I know you will have the X44 connector but may not have the 20 pin Molex Stac64 connector that has your voice command high/low, wheel speed high/low, aux l/r/detect, etc
