Custom Bose Bypass Harness
abizzle
357
85
Baton Rouge, LA
2018 Regal Sportback Essence
I’ve stopped buying things from PayPal and EBay because of a $200+ purchase I made long ago that went bad. PayPal wouldn’t return my money so they’ve lost me as a customer for life. Similar rule in place for Amazon for a different issue. I paid full price for my cargo rail from a GM parts seller rather than the heavily discounted prices on eBay just because of this.
Good luck with your claim.
By the way, I tried to pull my USB/Aux assembly out and had trouble getting any sort of leverage. Screwdrivers are too long to get under the little pry point and I think I need something with a thin 90 degree angle. I need to look around the house to see if I can find my iPhone try tools.
Guess what?! PayPal approved my claim and refunded me $44.50. I also get to keep the USB module, which I can save as a spare or sell on eBay or something.
I got a phone number from an Impala forum for a lady named Jenny Davis with JD IVI Systems LLC, and I contacted her about the USB modules. She clarified that the USB module I purchased from eBay was specifically for ‘14-‘17 year models and it would have been compatible with HMI 2.0. She said she had a module with two USB ports and a 3.5mm audio jack that would work in my car. The hurricane delayed the shipment for a few days, but I have it and will install it tomorrow. No SD Card, but at least I can have two USB devices connected simultaneously.
abizzle
357
85
Baton Rouge, LA
My quest to upgrade the factory USB module in the center console is finally complete. I have replaced the factory-installed module, part #13596807, with part #13519224 and it works flawlessly.
I now have two power/data USB ports and a 3.5mm analog audio jack instead of just a single power/data USB port.
So, just to clarify the part numbers I tried, their port setup, and whether or not they worked, here’s a list:
Part #​
Description​
Compatibility​
13596807(1) USB PortFactory Installed Module Full Compatibility
22990883(2) USB Ports
(1) 3.5mm Audio Jack
(1) SD Card Slot
USB Ports - Power Only
Audio Jack - No Signal
SD Card - No Signal
13536589(1) USB PortFull Compatibility
13519224(2) USB Ports
Full Compatibility
abizzle
357
85
Baton Rouge, LA
Part #​
Description​
Compatibility​
(1) SD Card Slot
SD Card - No Signal
Full Compatibility
I‘m still hoping to find a compatible module with the SD Card slot, but I can work with what I have.
