Has anyone replace their Tourx wheels?
You will need hub-centering ring if the bore is larger. I wouldn't recommend going to much past 32mm offset at 8.5" width.
Hub centric rings help but aren't required. I run a set of winter wheels on my wife's truck that are oversized, you just have to take your time putting them on.
I think someone here was able to get a 24 to work but it looked tight. So your number sounds safer.
Someone is claiming that that the wheels from these cars can be used on Regals... I wonder if this true.
- ET-42 off set -5x120
- Acura MDX: 2007-2013 and from 2017-2020
- All BMW 3 series 5 series 7 series x3 x5
- Buick LaCrosse
- Chevy Camaro and Equinox
- Honda Odyssey Passport Pilot Ridgeline
- Land Rover and Range Rover
- Lexus LS
- Buick LaCrosse
- Lexus LS
I think most of those are 5x120. I think there is some confusion since I believe Holden runs a 5x120, here is a list I found of cars that run a 5x115 pattern. No idea if the offsets work. 5x115 - Bolt pattern - Wheel-Size.com
This confusing some resources state 5x120 bolt patten others 5x115 pattern... I think Bolt Pattern 115mm is used with tourx
BrandFactory OEM
MaterialAluminum
Size18" x 8"
Diameter18"
Width8"
Lugs5
Bolt Pattern115mm
Not my car but someone on Opel Insignia B FB page posted their car with these 20’s. I’m not really into changing wheels but these look really good to me.
Just installed 2020 Caddy CT4 19" wheel option on my 18' Tourx. Everything fits with no issues. I went with 235/45/19 Kumho Majesty tires to keep the ride as close to stock as possible. The ride is a tiny bit harsher on impacts but overall very close to stock with better roll resistance. The wheels are $2000+ option on the CT4 and I got them for $800 on eBay. The CT4 wheel is 8" wide and a 35mm offset as opposed to 40mm for OEM and no fitment issues.
Those look great, nice option to explore!!
Those would be kinda cool.
Seeing the success that people have had with 2017-2019 LaCrosse wheels I'd be cruising the scrap yards to see if one would come in with some sort of damage where the wheels still looked good.
You are right, perhaps 2017-2019 LaCrosse wheels are the best option, even they are Chinese made but made to OEM standards. I would say 90% of all wheels on the market are made in China. My Fiat 124 Spider also comes with Chinese OEM wheels.
  • Like
Reactions: D2R
Could have swear those are the same rim on the sportback.
Rim Diameter: 19"
Type: Factory OEM
Rim Width: 8.5"
Offset: 46.5mm
Some come with Offset: 34mm
Bolt Pattern: 115mm
Your chart listed Mailbu - I was kind of wondering about the wheels on the current RS package Malibu. They were attractive to me but I don't know if they're as wide as the ones on our stock TourX. (The rest of the RS package meh, you can put the RS package on a 1.5T CVT Malibu for god's sake.)
