Smballin85
- Oct 24, 2020
- 2011 Buick Lacrosse
I have a 2011 Buick lacrosse
my issue is the driver side window switch. The driver side window works but the 3 others do not work however they work fine with there respected door. The side view mirrors also don’t work. I was thinking it might be the switch but I see the window switch and the mirror are two different switches. Would it be the wiring? What is your suggestions before I start digging in to it.
Probobly unrelated I do have a starting issue I believe is the starter. It makes a single click. It’s getting worse and it takes about 5 turns of the key for the engine to crank over and start. I got a new starter I’m putting on Monday.
This window switch has me stumped. Also do I need to remove the door panel to access it or will it “pop” out. Thank you
