All my ECM tuning and such revolves around my 03
Cobra. All said and done that was an over $10K exercise. Would I do it again? Absolutely. Before that was just a lot of old school hot roddng and engine, drivetrain builds.
The
Cobra and the TourX have something in common, they were both designed by the manufacturer for boosted application. actually they will take a lot of boost.
On the
Cobra I went beyond a pulley and a tune because the OEM Heaton supercharger just sucked. I meant Eaton Supercharger.
I could not deal with the heat soak and loss of power.
Lets look at cost performance benefits of modding a 2.0 LGT.
First off, you have legally voided the power train warranty once you load anything to the ECU. Gone. You can't hide that you loaded software. If GM looks, they see it has been modded,. The dealers are instructed by GM to look.
I gave up the powertrain warranty on my Ford with a little more than a year left on it.
I figure than other than inevitably puking out +$10,000 dollars of drivetrain parts, trany, clutch, driveshaft parts, axles, rear end gears, etc. I don't expect the engine to fail. The engine has never had a valve cover lifted, and as long as I don't do something stupid will be fine for another 100K to 200K miles.
Other than maybe the direct injection system on the TourX's 2.0 LGT, I would expect that to be durable also.
First level: (A good tune)
On the 2.0L LGT a $500 tune is advetised to geain 50 HP on unmodified motor.
A stock tour X is at best a 6.5sec 0-60, 14.6 to 14.7 @ 94-95 mph car.
Another 50 solid HP ought to get you a honest 14 Flat, +100 quarter and sixty just under 6 sec.
Other than than warranty loss, such a deal at around $500!
2nd Level (Basic mod's)
Custon 93 Octane tune plus
ZZP LTG Malibu/Regal O2 Housing
and
LTG ZFR Turbo
This ought to yield about 90HP over stock to get you a honest 13.7sec @ 103-104 mph quarter and sixty kike a WRX.
Cost about $3,000. Downside, not much. The GKN drivetrain is fine at this level and you are still not exceeding the AISIN transmission, but the margin has thinned. At his level the car is borderline fast & quite streetable. I would not loose sleep of stock engine internals.
3rd Level (Getting Serious)
Big bad Turbo, Maybe E85, Lots of supporting
mods,
Getting to the 400-450HP level , (Boost and Fuel Dependent) is going to cost you.
Figure $8-10K.
Even with torque management in the tune, with repeated hard use I suspect is going to hurt the transmission, and eventually the drive train and motor.
All that for low 13's @ maybe 110 mph. Doing this might be worth it for braggin rights on owning the fastest TourX and I might be wrong on durability, but the TourX still would not be a "fast" car, but a cool toy.
4th level
Getting Stupid. Rather than getting stupid, suggest just getting a stupid fast car, not a Buick.
