The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
88 E15, because I can.
dont confuse required with recommended. Real life I see 2 degrees knock retard with 93E10 and 4 degrees with 88. Not worth the money.
If it's retarding timing, knock is occurring and it's damaging your engine. In other words, it's too late to apply the brakes once you have crashed into the car ahead of you, the damage is done.88 E15, because I can.
I absolutely feel a difference running 93 vs 87. But I've been running 87 lately to save a few bucks. Yes, it runs fine with 87...but throttle response is slightly less responsive.
Economy was worse while using 93, but I attribute that to more aggressive driving.
Octane does have an effect on power if the motor is tuned for 93 octane. It will pull timing and reduce boost if it's a turbo and you'll feel less power with 87 octane.
Yes it does read this, and note the bold letters I highlighted that prove what I said in my last post:
The higher the octane rating, the more the fuel can withstand greater pressures without pre-igniting. This allows for a variety of options that can increase power and efficiency. These options include increasing the compression ratio, increasing boost pressure, changing the timing of spark ignition, injecting less fuel into the cylinder, and more. Additionally, engines designed to work with higher octane also burn the fuel more completely getting the most bang for the buck for each power stroke.
So, to summarize, the additional power that you get from a 93 octane tune allows for more aggressive tuning parameters because the fuel will not pre-ignite when compressed at higher levels. More compression = bigger bang/more power.
