Opel Part Numbers for your Sport Tourer
Price for the rear parts needed to DeClad TourX ?
39117536
39112658
39112659
Will send price quote later once will have price.
Need to understand that starting 2021 GM and PSA group killed their pricelists so all P/N now goes only on request and it takes some time until GM responds.
Waiting solution from their side about price-lists.
That would explain a lot as to why finding parts and prices online for the PSA Opel models has become a PIA.
Fortunately I think I got what I need used out of Poland. But know others would still be interested.
39117536
39112658
39112659
So got prices here:
GM 39117536 = 133
GM 39112658 = 461
GM 39112659 = 461
Prices in European EURO. This is what we can offer you.
So got prices here:
GM 39117536 = 133
GM 39112658 = 461
GM 39112659 = 461
That sounds about on par with what I have heard.. good that you can still get the parts.
I fortunately found these in Poland 🙂
Total was $1,250 US delivered to my partner in Poland 🙂
Fortunately I also have a crate shipping to the US from Poland so it won't cost me a fortune to ship either.
No description available.
Yeah buddy. Used always will be faster and cheaper!
So thats good. Happy about you.
Especially when looking for an assembly.. I will definitely keep you in mind though.
I know I got lucky and there are others wanting to do this..
My jaw dropped to the floor when I saw an OPC bumper listed on the Polish site, and for the price of a standard bumper..
Yep.. I am keeping with the TourX style. Its actually more the Sportback. BUT the European ones don't have the reflector on the fender 😉
So using a European front bumper will give it a more "correct" look.
This with the GS side skirts and the OPC skirt..
I believe that is the OPC "kit" for the body.
  • Like
Reactions: D2R
This regular EU specs Insignia Sports Tourer, not OPC line
Looks like it says OPC to me 😉
Just scored the Bumper for $180 in Poland 😉
JUST found out.. Seems OPC died sometime around 2018-2019
The OPC Sport Tourer was a prototype and there never was an official one..
So guess I will be the first 😉 Looks like all it is a sport tourer, with a OPC badge.
FWIW if someone else is looking to rebadge.. >>
Tough call if it doesn't sell, I will have three steering wheels and only two airbags. I can get another air bag but it will cost be $250 and as I personally don't need one. Not sure worth the hassle.
Opel steering wheel will be a tough sell since only one person claimed that he was able to successfully retrofit Regal without showing any detailed photographic evidence. Buick's steering wheel has different connectors, harnesses, and slightly different functions I doubt that it can be easily transplanted.
Actually told quite the opposite.. US connector fits ALL 2018 Regals
ALL 2018 - 2020 Regals ( w/o Heated wheel )
ALL 2018 - 2020 Regals ( with Heated wheel )
Standard Opel Wheel has same plugs and thus would seem same harness as well
Now from all my comparisons.. I have done..
The pin outs look the same.. for the controls and the airbag. Even the Airbag connector.
Confirmed 39136242 the part number of the clock spring is the same.
The ONLY difference is the same as if you swap a Heated wheel with a non-Heated wheel. You need the wires for the heated part..
It DOES seem if the Flat bottom one with the paddles does have an extra connector and doubtful the paddels would work with the harness, but there for looks. The Standard wheel though does seem to not be a problem.
So not sure where the info that they are different came from, but I can't find any difference in wiring or harness.
GSi/OPC Wheel with paddles
Standard Opel Wheel
Also no different functions at all.
All the controls are in the same place.. the exception is the paddles.
Which simply will be there for show
Otherwise its' simply a different look and size for the buttons.
The connectors look the same to no surprise that they would fit togerther. However, and admittedly it is hard to tell from the photos, but looking at the ones I can see the wires going into the Buick ones don't look the same or to be going to exact the same pin position.
The connectors look the same to no surprise that they would fit together. However, and admittedly it is hard to tell from the photos, but looking at the ones I can see the wires going into the Buick ones don't look the same or to be going to exact the same pin position.
It is hard, as I could not find the harness or part number in europe and could only go by the pictures.
But while the harness maybe different, I wouldn't think the pin out at the Car side would change.. Why would they do that ? Now would the pinout on the plugs change at the switches ? Sure, different switches with different slight configuration issue.
I will say its wierd like the air bag.. BUT while the colors for wires and some connectors are different.
The same wires go to the same pins for the air bags connectors for instance the others are hard to decipher. Maybe its a DOT vs EU thing..
It would make them have to make two different parts. Also as noted by two others they have simply plugged in the Opel harness and it worked with no codes. That straight forward.
Everyone is assuming they won't work BUT ignoring the fact that others have already proven it does.
I guess the real issue for me is that I already have 3 steering wheels and 2 airbags so I will know for sure. Its just that getting another airbag would be another $250+ and I would only be getting it for someone else.. That said, the kit I have already gotten, would need that air bag.. so I might as well get it.
