Have a 2016 cascada having issues with the xm radio dropping the signal. Really love my vehicle but not happy that I am paying for a radio subscription and cannot use. I think this is a Buick issue because my wife's Honda works just fine!
The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
I have a 2011 Lacrosse and my wife has a 2015 Enclave. My Lacrosse has no issues with XM reception while driving the same route as my wife back and forth to work. My wife's 2015 Enclave drops reception 5 or 6 times per trip. My wife is considering dropping the XM Radio and trading off the buick since she really likes XM. I will go down the path of arguing with the dealer but this one seems obvious to me.
I had the same issue. Here is how I fixed it.
Enclave XM Signal Loss | Buick Enclave Xm signal Fix
After extensive research and an expensive OEM antenna replacement, I found out that the OEM antenna runs 3 devices. On Star, am/FM radio and the xm module.
I came up with the fix above and has worked flawlessly. No more dropped signal!!!
Hope this helps.
I have the same problem with my 2015 Enclave I bought used last year. It dropped radio signal frequently and then recently quit working altogether except for occasional spurts. I would like to try this fix but don't have a clue how to run wire outside to antenna to keep it from being caught in the hatch or how to hide it entirely. Can you explain how this is done?I used jergraphx method and have the same positive results. I had one of these antennas in my old Dodge Ram and when I switched to my Enclave I experienced signal drops from trees (with leaves), cell towers, and even on cloudy days. Now that I have switched my signal is more like what I had in my Ram with the only drops being tall buildings and occasional overpasses. Haven't had any low ceiling clouds yet to verify that improvement. I have not ran the antenna permanently as I need to do further research on accessing the rear panels but the current placement seems okay but the antenna wire runs close to hatch motor gears and hopefully it doesn't get caught up in those. Thanks jergraphx for the link it helped out greatly.
I have a 2014 Enclave that I bought as pre-owned. We registered my vehicle as replacement for my Ford Escape. The XM worked flawlessly for the first 3 months. Since the beginning of June I have had sporatic service or no service. Today we turned the radio on and had reception. After church no reception. Frustrated I called Sirius and after a CSR failed to resolve the issue I waited for a manager. She told me it's not an adapter it's a module. Yet I can't get any info on a satellite module. I've been given the run around repeatedly. I'm curious about your post about tge OEM antenna. Can you helo me with where I get one and how do I get it installed?I used jergraphx method and have the same positive results. I had one of these antennas in my old Dodge Ram and when I switched to my Enclave I experienced signal drops from trees (with leaves), cell towers, and even on cloudy days. Now that I have switched my signal is more like what I had in my Ram with the only drops being tall buildings and occasional overpasses. Haven't had any low ceiling clouds yet to verify that improvement. I have not ran the antenna permanently as I need to do further research on accessing the rear panels but the current placement seems okay but the antenna wire runs close to hatch motor gears and hopefully it doesn't get caught up in those. Thanks jergraphx for the link it helped out greatly.
I still have not ran my wire "permanently" neatly hidden and my "temporary" run is more and more becoming the permanent fixed. I will try to post some pics in the next couple days of my run.
I have the same problem and recurved the same responses! Wish I would have found this forum earlier====================================================================================================================
I am experiencing the same satellite radio signal loss problem as JuliaMc, but my dealer won't do anything about it. They say it is normal, according to a Buick technical bulletin.
VIN: 5GAKRCKD8EJ181979 Dealer: Covert Buick GMC Austin (512) 371-6069
Contact Info: Merrick Leler merrickleler@gmail.com (512) 914-3274
Hope this helps.
Im having the same issues and so im going to listen to everyones advice and get a magnet antenna 🤣. Had XM refresh several times with no luck. Mine said NO XM SIGNAL. I hate that we all had to come to fixing this issue ourselves this way. Its a shame BUICK cant do "anything" about it 😑Jergraphx, based on the info you'd provided and the website, I did some experimenting when our XM suddenly went perma- "no XM signal" yesterday in our 14 Enclave, with no change after radio refreshes. Short version of story is after removing the yellow Fakra plug from the antenna, I ended up using a 90-degree plug magnetic antenna from an old Sirius radio I have around and it popped into place on the XM module in the jack space and a few seconds later, I had Andy Gibb blasting way too loud over 7 for 70's. Not sure if it's going to stay attached without the Fakra clip on it, but a short drive around town and so far, so good. A strip of tape over the plug will hopefully keep it stuck in well enough for regular driving.
Prior to that, I had verified that the Onstar worked and the digital radio seems fine, so, it's just the XM portion of the antenna feed that's the problem.
Do we know if this is mostly an XM only issue or do the other two devices also suffer independent failures, but I don't know about them because I'm not looking for radio or Onstar posts in the forum?
Also, when it is the XM portion, do we have any idea if it's the actual antenna itself or is it the run of cabling that connects from the antenna plugs and goes through the ceiling cover to the various modules? If you watch this about an antenna replacement on an '11 Equinox, you'll see what I mean.. I'd go for replacing the whole antenna, but don't want to do that to just find out it's a break in cable harness from there to the module in the hub. My '14 has the middle seat belt in the ceiling back there that the Equinox in the video doesn't and I'd rather not have my wife mad at me for taking the ceiling apart unless I know pretty much for certain that the antenna replacement will fix it.
So, for now, I guess the magnet antenna is going to stay on the roof.
Help I have the same issue. 2016 Buick cascada. Sirius radio constantly fades in and out. Impossible to listen to. Is it the antenna or is it a defect in the radio? Very frustrated. Please help.Hello JuliaMc,
I can completely understand how frustrating this XM radio concern must be for you, especially so new into your vehicle ownership. We’d be more than happy to look into this situation, please send us your VIN, contact information and name of dealer at your earliest convenience.
Best regards,
Anthony J.
Buick Customer Care
I purchased a 2016 Cascada in June. Could not receive a Sirius signal. Sirius tried hard to help me but finally said it was an issue with the car. I returned to the selling dealer and they diagnosed it was an issue with the antenna wiring. They installed a COMPLETE antenna system and that did the trick. Lucky for me it cost me $0. I'd suggest you visit the dealer and good luck.Help I have the same issue. 2016 Buick cascada. Sirius radio constantly fades in and out. Impossible to listen to. Is it the antenna or is it a defect in the radio? Very frustrated. Please help.
Sean
