GottWhat
- Mar 7, 2011
- Shelby Township, MI
- 2011 Buick Regal Turbo (T06)
Do you have another dealer nearby that you can take it to?
The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
I noticed your post on the other thread and would like to look into this for you. Please contact me for more assistance.
Did you end up going to another dealer then? Not sure exactly the rattle you are hearing or EXACTLY where its coming from but make sure your '11 has been updated with a TSB that covers a loose tail lamp assembly mounting. My dealer fixed mine some time ago and a buddy of mine bought the same year Regal and had the same rattle....passenger side. Tricia might even be able to find the exact TSB #...it will give you some ammo when you go back to the dealer that way!!Strut and strut mount ordered......keep your fingers crossed.
I would say that my car exhibits the exact same noise as yours. I have the rattling/ loose suspension noise, and overall, the passenger side is much louder over bumps than the drivers side. Does anyone here have a 2012 , and does it exhibit the same noise, also what trim level. I have a t07 with the 19s and selectable suspension, if that makes a difference.The funny thing is they fixed mine but I think all it did was cure the rattling/ loose suspension noise. I swear when I go over rough roads the front right suspension is much noisier than the left. It sounds like a magnified hollow noise when going over choppy roads.
It looks like we are in the same boat.Still same noise here.... only right front side, hit a bump with left, and its solid, no noise, and yes, replaced the strut and some "link", no dice.
My car has been making a similar noise for the last several months. After MANY attempts to have the dealer fix it they were finally able to hear it last week. They claimed they "fixed it" but after a day it was making the same noise only this time worse and significantly louder. Finally this past week, after they took the whole front apart, they discovered it was the Axle that now has to be replaced. The car is barely a year old and I've already had a taillight replaced because it burnt out, some plugs in the engine replaced, the heated seat element on the driver side back and bottom both needed to be replaced and now the Axle...what a joke!
Hate to say it, 2012 Premium 2 eAssist here, fresh from the plant in January, and have a very similar problem. Front passenger wheel, noise for me can only be heard when slowing to a stop (right at about 1MPH), regardless of whether brakes are applied. My situation may be slightly different since crossing speed bumps or other road irregularities does not produce the sound. I finally decided to investigate it over the weekend to see if I can reproduce the symptoms easy enough to take it in. I popped the hood, stuck my ear to the strut mount, and gently pulled upward on the frame of the car; sure enough a pop noise can be heard on each tug. Took it into to show service dept on Saturday and thank goodness, was able to reproduce this with the technicians there. I am scheduled tomorrow to bring the car in so they can begin to investigate and render a remedy. I will keep everyone posted.
Anyone else able to replicate by tugging upward on the frame of the car?
