It is the fob, I don't know why anyone would suggest it is the pad on the trunk.
If you press and hold the trunk option, it opens within less than a second and I believe because it is in the middle of the fob it has less friction to contend with. Lock/unlock/panic all have multiple edges, trunk and remote start have one edge. However, remote start requires you to press lock before it will remote start, even then the time it requires you to hold the remote start button is a lot longer then the trunk.
I am on my fifth trunks open, pull over and close it. I can contribute each time to one of three things.
1) My pockets are over stuffed.
2) I laid on my pocket.
3) I have a few small lock box keys and my wifes ford key (no house key). If I don't fold it into my pocket with the back of MY fob against the back wifes key, my trunk will open.
Most of the time an early warning sign that has saved me once or twice has been if I felt that my key was extended I knew things got depressed and have been able to close my trunk before leaving.
The only thing I could foresee Buick doing outside of completely redoing the fob is different pattern, such as press + press and hold (press and press within 2 seconds, then hold for 2 seconds). Or a lock or unlock then trunk release (within 2 seconds) pattern. With the current fob and pattern it is way to sensitive and easy to open.
I thought about ordering a new fob that has less sensitivity, but I know what the problem is and how to avoid it, so it hasn't been that big of a deal (ie, it hasn't rained in my trunk yet hehehe)...
