hoffmantre
- Jul 22, 2018
The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
He mentioned in another thread that the black pieces on the bumpers are molded in and not removable. OP is apparently planning on replacing the entire front/rear bumpers.Is the black portion on the bumper not removable? Looks like just the last trim that goes down to the black.
What build up of water are you referring to? Fenders/bumpers without cladding will not accumulate water. Maybe I'm missing your point.looks wise, I prefer the cladding on.
But with the cladding, water will probably hang around much longer, keeping the area moist and more likely start rusting earlier.
Once the Rust starts taking shape, you can put the cladding back on and hide it !
And then he says when the rust starts you can put the cladding back on. I'm confused.I think he's saying the cladding WILL hold moisture...
Once the rust starts it looks ugly. You can cover it up by replacing the plastic cladding you had taken off preAnd then he says when the rust starts you can put the cladding back on. I'm confused.
Are you keeping the rear bumper? If not, where are you getting it from? I think Europe is our only option, especially if you want the OPC/GS design.I have the side skirts on the way and I plan on buying the bumper too
If you look at the parts diagram online on GM Parts dealers it shows the front bumper cover has a separate cladding trim piece. It also shows that the bumper cover has ridges where the cladding goes. The diagrams are drawings not pictures so we can only assume that it could be an easy removal and reveal.Wondering if that last piece on the front wheel wells can be removed as well. If the OP would post how it was done, that would help too...
