I Removed the Plastic Cladding Trim on the Tourx
looks wise, I prefer the cladding on.
But with the cladding, water will probably hang around much longer, keeping the area moist and more likely start rusting earlier.
Once the Rust starts taking shape, you can put the cladding back on and hide it !
Nice job! I thought I might want to do this to mine, but I'm not up for replacing the bumper to finish it off.
Is the black portion on the bumper not removable? Looks like just the last trim that goes down to the black.
He mentioned in another thread that the black pieces on the bumpers are molded in and not removable. OP is apparently planning on replacing the entire front/rear bumpers.
If you are going to the trouble of removing your bumper why not just remove the existing pieces and cut off the remaining piece of cladding with the bumper assemble off of the car?
What build up of water are you referring to? Fenders/bumpers without cladding will not accumulate water. Maybe I'm missing your point.
I have the side skirts on the way and I plan on buying the bumper too
Are you keeping the rear bumper? If not, where are you getting it from? I think Europe is our only option, especially if you want the OPC/GS design.
hoffmantre, how did you remove them? Heat, solvent, brute force?
Damn.... Now I'm tempted to do the same... Just need to see how you did it first! 😀
Wondering if that last piece on the front wheel wells can be removed as well. If the OP would post how it was done, that would help too...
If you look at the parts diagram online on GM Parts dealers it shows the front bumper cover has a separate cladding trim piece. It also shows that the bumper cover has ridges where the cladding goes. The diagrams are drawings not pictures so we can only assume that it could be an easy removal and reveal.
Should removal of cladding be known as De-Aztecking?
Subscribed for more results on the decladding process. I also like the Opel look better. And how do we lower the ride height down the couple inches Buick decided it should be raised?
I'm about to pull the trigger on a black Tour X. I don't care for the cladding either. I like what you've done so far. I wonder if the piece circled in my pic could be removed and look as clean as the wheel wells? If so, I think I could live with removing all of the wheel wells and replacing the rocker trim with just the painted rocker pieces. Not too much $s either. Please keep us updated Hoffmantre.
