BahamaTodd
3.8L Member
- Apr 7, 2017
- Palm Beach, FL
- 2018.5 Regal GS
The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
Will not let them update my software. They might try to make my red needle car, as slow as white needle cars.TSB 19-NA-100 Radio Software Version 22.8 Over-the-Air Update - Nov 4, 2019
Only applies to 2018.5 and newer cars with the new infotainment system.
Although the TSB document is out it doesn't look like the update has been pushed out to vehicles. When that happens its usually automatic (if the auto update is selected). I plan to take my car in this week for the reverse camera update and I'll see if the infotainment update is available for the dealer to install manually.Has anyone been able to successfully update over the air yet? Mine currently says no update available.
I need to schedule an oil change soon anyways, so I can always ask the dealer to update.
Thanks. Added to the original post.What if I tell you there is 22.9 SW already?
GM Infotainment Update Resolves Grayed-Out Favorites Issue
What is this reverse camera update you mentioned? To fix the disappearing guidelines?Although the TSB document is out it doesn't look like the update has been pushed out to vehicles. When that happens its usually automatic (if the auto update is selected). I plan to take my car in this week for the reverse camera update and I'll see if the infotainment update is available for the dealer to install manually.
YesWhat is this reverse camera update you mentioned? To fix the disappearing guidelines?
How slow is my white needle?Will not let them update my software. They might try to make my red needle car, as slow as white needle cars.
What speed does your white needle hit the rev limiter in 5th gear ?How slow is my white needle?
The last gen Regal required XM to get live traffic. So they changed it to OnStar now? That is bloody expensive comparing to XM.I have the same question. On my 2018.5 - "no update available" and the last update was sometime in March 2018 😕
Note: I have not subscribed to OnStar, or the 4G Hotspot service. I noticed that Live Traffic updates stopped after the trials expired.
Are the "over the air" updates supposed to work even if you have not subscribed to the connected car extras?
