BenD
- May 20, 2020
- 2019 Regal GS
Dan,
Is Speedway serving top tier gas in your area?
They certainly aren't around here.
Good point D2! Be careful with cheap fuel, remember that fuel additives package are different from a Brand to another and cheaper fuel also mean cheaper additives package.
you may pay more but getting a good fuel quality and long term, you’ll save on maintenance, fuel consumption etc. A clean system will keep the performances specs close to 100% day to day.
Think about replacing an defective injector because of the dirt, how much it is ? 60$+.
Let say 60$ so if you save 5 cents per
Liter by buying cheaper fuel, so 60$ means 12 fill up with 5 cents discount ? At the end of the day, is the 5 cents saving worth that 60$ part plus labour, plus wasting time etc etc !
Also, forget about adding any aftermarket fuel treatment/cleaner etc in fuel...DONT DO THAT.
that could cancelled the fuel additives jobs in your fuel (anti-foaming, anti-wear etc) Same things on the lube side.
