^ this suggests there's a physical communication problem (temporary?) between the reader slot and either cardRemove factory SD card and insert cloned card into my wagon, then turned it on.
Go to navigation system and the infotainment tries to load maps.
"SD card has been removed" message shown on screen.
Turn vehicle off and then insert factory card back in.
Turn on vehicle and head to navigation system. Still same error message.
^ this suggests the NaviUpgrade card is being read, but deemed invalid for your systemStarted vehicle with the factory card, navigation system loaded up.
Switch over to audio and then swapped the SD card. Headed back to navigation system and this time it says this SD card is not for this navigation system.
Swapped back to factory card and the navigation system works again.
^ if there's a physical communication problem, again, you would never get to theTried the actual SD card that was delivered, worse than the cloned card.
Never got to the message that says this SD card is not for this navigation system.
Only stuck with SD card removed message.
message.This SD card is not valid in this vehicle for navigation ... (Error Code).
, which seems like it's working, but after multiple (5 ?) ignition cycles you'll getOnce initialized, this SD card can only be used for navigation in this vehicle.
I totally agree the CarPlay works good. However, it requires a wired connection and our Regal is sorely lacking the space to place the phone with it.I get it that our cars came with Nav but it is sooooo much easier to just use Android auto or apple car play. Google maps is going to be much more current and have much better traffic info than Nav on an SD card.
I just like the built in Nav interface better and I don't like losing the bottom ribbon on the screen with Carplay. FWIW I just took a long trip and the updated maps I recently bought and installed had the newer roads and POIs that the old maps did not but admittedly they will be out of date where any new construction is involved.I totally agree the CarPlay works good. However, it requires a wired connection and our Regal is sorely lacking the space to place the phone with it.
yeah, no, that didn't work 👎I'm still testing removing all partitions readable in Windows from a NaviUpgrade card and then copying the data back to the card. This, i hope, won't affect the hidden Android "initialization" data, but will remove the erroneous overlapping extra partition showing up on those cards, similar to agaric's idea.
If it works i'll post back the process...
(0x10000.3195.014A.3195.014A)
Which eBay listing?I decided to take a flyer on a card from NaviUpgrade on eBay. Mostly because eBay has a great return policy on car parts. You'll see cards for sale that people pull out of wrecked cars. But we all known those do not work. The NaviUpgrade card did though. My system did ask if I wanted to initialize it and that it would be locked to the car. But it's been smooth sailing and I'm now on the 2023 maps. I have a 2018 white needle.
Thanks, worked for me...
I finally installed our card from NaviUpgrade and it eventually failed validation. They are advertising 23 sold - no way they have 30 + actual new GM SD cards.I decided to take a flyer on a card from NaviUpgrade on eBay. Mostly because eBay has a great return policy on car parts. You'll see cards for sale that people pull out of wrecked cars. But we all known those do not work. The NaviUpgrade card did though. My system did ask if I wanted to initialize it and that it would be locked to the car. But it's been smooth sailing and I'm now on the 2023 maps. I have a 2018 white needle.
...because i'm ignorant of Linux & Android 🙁Not sure why all the talk about files and etc. as a true image is independent of the file system...
Never thought of that 🤔...one seller who was selling used cards... His used cards also always came with the card reader out of the salvaged car. He always sold them in a pair, ...leads me to believe that the reader has some unique identifier and that's what they use when a card is initialized to a car.
...looks to be working 🙂pulled out of a brand new 2023 Cadillac XT6... it was in the vehicle manual kit / binder of a brand new rental and I don't believe the car had been set up
& now they're advertising GM - INFO 3 MAP UPDATE - V.2022-5, GM #85618592 for Encores, Enclaves, Cadillacs & Chevys...wondered if this one would actually work GM - INFO 3 MAP UPDATE - V.2021 | HERE
🤔This new release is available for pre-order. It will not ship until the product is in-stock approx. May 23rd. Your credit card will not be charged until the product ships. Rush shipping will not be honored.
1) This is a non-refundable map update. Once opened, it cannot be returned
Maps are made(just security portion)to your vin and you can't use it from different vehicles.gambled on a #86810236 off eBay, listed & described as;
