2011 Lacrosse Trunk Mysteriously Opens
I can hardly believe it, but this morning when I went out to the car it had it's trunk wide open. It took 1 year and 15,000 miles to happen but it did for the 1st time this morning. Car had been locked and was parked outside.
I just had the remote control receiver replaced in the car which has fixed it's short range issue now all of a sudden the trunk pops itself. Hmmm, connection?
Well, you just answer one of my questions, it looks like it does not matter if it is locked or unlocked.
I am now wondering since it only happened after you had the remote control receiver replaced in you car if the receiver has something to do with the random trunk open issue that the rest of us are having?
Make sure you report this to Tricia.........
Seriously, please lay off the Customer Service Reps. They are here to assist in whatever capacity they are able to. I'm sure there are dozens more dangerous car issues than a phantom trunk opening. If you are that paranoid about it disable the trunk popper.
I personally had it happen twice in a year and one time I know the fob was in my pocket and the other I was in the trunk prior so I'm not sure I shut it properly. I'm not worrying about it.
The fact is any dealer is going to have a tough time fixing a problem they can't duplicate. These types of behaviors are going to happen more and more with how complicated today's cars are.
We, the owner, shouldn't have to perform a "fix" on a known issue with these cars. May your trunk pop open on you when you have something valuable in it or open when it is pouring down rain.
Unless fixing the range of his remote allowed his fob to now be depressed inside whereas it wouldn't had reached prior?
Thanks for the ill wishes at something that wasn't directed toward you. I agree these things shouldn't happen, however, the person I was replying to was being rude and disrespectful to someone who is just trying to help with whatever resources they have available.
It's Sunday, a nice day for watch some football and let the wife go shoppng. Til you get a call from the wife that someone broke into the car.
There goes Football Sunday...You race to the mall to find the wife and the
security guard standing around the car. TRUNK IS OPEN! Trade cars with
wife and go home. It happens on a couple other occasions- TRUNK OPEN!
Call dealer- they have no clue.
Call CUSTOMER SERVICE- talk to probably the Philippines... THEY WILL
FORWARD THE PROBLEM! And you will get a call from your dealership when
the problem is solved.
THAT CALL IS MADE OVER A YEAR AGO! THEN YOU WONDER WHY PEOPLE
MAY NOT HAVE AS MUCH FAITH IN CUSTOMER SERVICE.
Guess I should cut off those zip ties that help the trunk lift itself... That was a nice feature, oh well *sigh*
Please verify, did someone actually break in to the car or did the trunk just randomly open? Was anything taken?
Please send this info to Tricia, the Buick Rep who monitors this sight.
My trunk has never opened all the way up and I am ok with that especially with this random trunk open issue. It may be a good idea to not let the trunk open all the way until this issue is resolved but that is your call.
GM should have more resources available for customer service after the sale. I'm not happy with my 2011 Lacrosse or Buick (GM) customer service.
"And you will get a call from your dealership when
the problem is solved."
Like that is going to happen. The dealership service department left me a couiple of nasty dings on my car and the service manager and general manager wouldn't even address that issue. All they would do was say "sorry".
Dealerships are independently owned. It sounds to me as if you need to go to a different Buick dealership. Also, consider that any GM product line dealership can work with you on a warranty or after warranty issue. A Chevrolet dealership or even Cadillac dealership repair shop may have a better response for you.
There are fixes for your problem.
What can they do? Well for starters either an employee or I would even volunteer to hook up some sort of data monitoring device to the car/lock to see if the signal is coming from the car it self, or the fob (if they can even separate the two).
If it is the FOB then they have to go to the drawing board with Strattec and come up with a new design. Preferably a barrel design as to not have a perfectly flat surface I feel would negate pocket-pushes.
Personally for PEPS FOBs I am not a fan of the swing out key, it is pointless unless your battery in your FOB or car is dead and you need the physical key. So with push button start cars, make the FOB smaller, sleeker, rounder. Put the blade inside the fob keeping it as small and neat as possible, add a release like Dodge does to get the blade out. Or give the customer more options, like a smartphone option that communicates directly with the car (no onStar middle man). Then they can decide if they even need the fob/key with them at all times.
For non PEPS FOBs go back to separate key/fob. These integrated key/FOBs are just too big, much bigger then when key-less entry was first introduced which is the wrong direction.
If it is the car some how unlatching the trunk on it's own, that is a huge problem, probably bigger then a FOB issue. If that type of gremlin was unlocking doors, you know they would be on it like butter on bread, so why isn't this any different?
But it will all start with Buick acknowledging a problem, which I imagine they don't like to do as it leads to recall$. Then it would require someone to monitor a vehicle that is known to have the issue for quite some time. The question is, how do we persuade Buick to go down this road?
My '09 (old body style) had an interior trunk release button that was implemented in a creative way. It was part of the door lock/unlock button on the drivers door panel. To open the trunk you would press and hold this door unlock button in the unlock position. It took a couple of seconds for this to cause the trunk to open. Worked well. Not sure why the same couldn't be programmed into the keyfob function button for the trunk.
Been there, done that. I get my work performed at the Chevrolet dealership in town now. Buick (GM) doesn't acknowledge that there is a problem. Their answer was not to keep the fob in my pocket.
Also if I remember correctly the Buick customer service rep on here was going to address the issue with the dings on my car with the Buick dealership. I haven't received an answer yet. It has been a long time. I think that they contacted the dealer however as the general manager seems to be po'd with me.
I will not buy another auto or have any work done at Medlin Buick in Wilson, NC ever again. However, they can still send me letters to for a free turkey like they did at Thanksgiving. I went and picked up a free $10.00 gift certificate. I did have to answer a short survey and I got the satisfaction of telling them how I felt about the car and the dealership all over again.
I'm leaving mine on. In 2 1/2 years my trunk hasn't opened once on its own.
I'd like to keep them but mine popped last week on it's own and I would have to say there's a big difference between zero lifetime pops and popped last week 🙁
I'm totally with you on that. If mine ever opens on its own, even once, the zip tie mod is coming off.
yeah having the same issue with my 11 regal. Its not just buicks tho, had the same issue with my 11 cruze.
