EXTENDABLE DRIVER SIDE SUN VISOR?
New visor arrived today, attempt one to remove the old visor, found the factory put self adhesive foam around the connector. Unable to disconnect with headliner still installed. Will attempt again tomorrow.
There was a guy on FB group that did with swap with a part from an Envision. He said same thing about the wiring under the headliner being the hardest part but it worked once he was able to figure it out.
Install went smooth today. Time needed is 30-45 minutes and for tools you need a small screw driver, T15 torx, and a 8 mm nut driver. Below are the pictures i took during the process. After you remove the screws from the visor and get the old removed(like playing tug of war with a gorilla), you have to remove the retaining clip for the visor, the assist handle and pop the A pillar cover free. This allows you room to disconnect the wiring. Once you have the old one removed, the installation is the oposite of pulling it apart. The only thing that my replacement had was standard bulbs, no LEDs. But guess what, GM is cheap and put LED replacements in place of the bulbs so they are easy to swap.
Note: this is the driver side visor from a 2013-2017 Buick Regal. I'd like to believe all colors are the same as well as the passenger side.
  • Like
Reactions: pek
Here are the pictures.
Thanks for pictures and the report. Got to do this, Hope the tan (Shale) interior color match is good. If anyone gets the Shale part numbers and confirms color match please chime in.
I second that!
  • Like
Reactions: D2R
According to GM the colors for the 2013-2017 come in Titanium, Cashmere, and Black. Of course the same color names would be too much to ask for 😒
From what I can tell the Sportback comes in gray or black and the Tourx is tan.
22800048 Sunshade/Sun Visor LH Titanium New OEM GM 2011-17 Buick Regal
Total: $53.99
Item ID: 232696092513
Seller: s1autoparts
I just got this on ebay. The color is slightly darker but I find it ok... I am looking forward to not having the sun in my left eye! Not the worst job to install but all the glued stuff in the headliner is a pain.
I just ordered two Envision ones off of ebay... $65 per, I think. I will have my A/V guy install them so I don't screw anything up. Driving almost due South to Austin last weekend was unbearable.
I was thinking about this yesterday. While I enjoy a project, I'm not sure I want to bother swapping the visor. I'm considering a cheap & easy solution. Either buying this, or making a simple version of it myself:
Amazon.com: SAILEAD Tan Beige Sun Visor Sunshade Extender for Car, Side Window Sun Visor Extender Windshield Sunshade and UV Rays Blocker, 1 Pack, Beige: Automotive
(Note, I have the Shale interior, but they have other colors)
Nice find, ordered.
(one of the features I wish this Xcellent car should have come with!)
DO NOT GET THE SHALE! They are the wrong color... or at least they were for me. I need gray.
If anyone wants to buy 2 shale visors, I'm sure we can work something out.
Hi GermyShoe - I am looking for a shale visor that extends. If that's what you have let me know.
