The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
Have not gone down to check out yet....but online they have steel set for same price. That are a little higher lift, but lower weight capacity. Thanks for tip on discount coupon.I found these ramps work perfect for my TourX. Perfect height to change the oil. And you can't beat the price, ....be sure to use a 20% off coupon found everywhere.
13,000 Lb. Portable Vehicle Ramp Set
Went down to Harbor Freight and was gonna get the taller metal ones, but when I took display out to see if it would clear the TourX... it would not.I found these ramps work perfect for my TourX. Perfect height to change the oil. And you can't beat the price, ....be sure to use a 20% off coupon found everywhere.
I would go to the dealer and ask for a quote. I found this here: Splash Shields for 2018 Buick Regal Sportback | GMPartsDirect.com
But it looks different than what I have but perhaps they are different between sportback and TourX. But my guess is this isn't right either. Can't believe that stamped steel with cut outs is only $20 so I think this must be plastic.
Whirligig may have started to give you a free oil change and forgot to put the shield back on?I'm in the same boat. My used Sportback was missing the bottom gravel shield as well. Any luck finding the part number for it?
Thanks
It would be nice if the next time someone here does an oil change to see if there is a part number stamped on their gravel shield. If there is one, then post it.
Not sure but sounds like maybe they did not have on 17 Regals without AWD?LJ, could you hand me the 12mm socket?
Seriously, I haven't had any luck finding one. I was over at the local Penske Cadillac dealer that handles Buick and they couldn't find the part either, weird.
I tried looking under a 2017 Regal, no luck. I may try looking under Opel Insignias next.
Thanks
If you have the fastners for it toward back of car it probably had one. Mechanic could have taken bolts out when he did not have to since that end has slots, and if loose would have fallen off most likely.I guess this begs the question, does a 2019 FWD Sportback come with the gravel shield from the factory?
