Hi All,
Sorry to necro this thread on my first post, but I had a few questions and this seemed to be the right (and most recent I found) place for them. Thanks to OP for pics and such! (Hopefully this shows up how I am expecting it to...)
1. Assuming I can get the under plate off before lifting the car, is there any consensus on whether it is OK to use the front subframe crossmember to jack the front (followed by jack stands at OP's suggested location of course). I just prefer to jack up one end at a time, as opposed to jacking each corner separately, preferring to shift weight around as few times as possible.
2. Has anyone considered installing an oil drain valve like this one:
F-107 | Fumoto® Engine Oil Drain Valves? I have one on my other car and it is fantastic. There doesn't seem to be a 2018+ Regal-specific product, but it seems like a M12-1.75 should fit based on this seemingly OEM replacement:
Buick Regal TourX Engine Oil Drain Plug Dorman 65430. Anyone think there will be clearance issues?
3. This one is a bit off-topic for just oil changes, but asking here to not have to necro two threads for two posts lol. What rear jack points do folks use if I wanted to rotate tires or something. I haven't found anything recent discussing that either. This might sound crazy, but has anyone tried using the rear diff (on AWD cars)? I know that's the rear jack point on my Subaru, err Toyota, err Scion... Anyway, based on some pictures from this thread (
Lifted TourX, Where is oil Drain plug and Oil Filter located?) it looks like it is pretty well supported by various frame elements.
