Lj said,
You do know that TourX has AGM battery and ideally needs more voltage then lead acid battery, which is what you seem to be talking about from your voltage numbers.
It appears a standard alternator charge of up to 14.4 volts will cause no issues with an AGM battery or any other lead acid battery.
If you do an Internet search on car forums you will find owners complaining of having to replace expensive AGM batteries, sometimes frequently withing 3 or 4 years, where prior to smart charging this did not appear to occur.
The link below has owner replacing a
14 year old AGM battery on a 3.2 TT with standard Alternator charging, this should prove that AGM batteries will not be damaged by a regular alternator, in fact they appear to last far longer without smart charge.
Take back control of your car.
From TT forum, Posted:
24 Nov 2018, 16:58
Just to complete the thread, fitt3d a new battery from euros at
£181. Took the old battery off and it was
the original from 2004, and showing 11.1v via code 20 on the recirc function with the engine not started
New battery on and code 20 now shows mid 12v with the ignition on but engine not started, with the engine started the alternator output is more stable with less fluctuation in output.
Other points car turns over much quicker, seems smoother. Hopefully fuel economy increases. If you buy a battery from euros you have to ask for it as the system, they use does not pick out agm for the TT
[/URL][/URL][/URL]
