Hi Guys,
I don't own a Buick but thought you might try this, I have been trialling this hack in the UK for over 6 months on both my Mercs, a 2012 C-Class coupe CGI petrol and a 2015 SLK petrol. It works without any issues on both cars, no warning lights on dash, Coupe just past it's MOT with hack in place, the battery on the C Class with stop/start is over 7 years old.
On the C-Class the Stop/start light stays orange (off ), on the SLK the light goes out ( off ).
It has also been used on BMW's also with no issues.
Lift hood, find main starter battery, remove cover, disconnect negative rail battery sensor, ( the sensor on the black thick battery lead ) wrap insulating tape round the contacts, replace cover, close hood, that's it. By disconnecting the sensor the ECU can`t read the SOC of battery therefore it does not implement stop/start, at the same time the ECU also instructs the alternator to change from smart to regular charging so the battery is now charged fully where possible instead of 80% as before. The charge rate is between 13.8 volts and 14.3 ( continuously checked over 6 months ), a bonus is with stop/start deleted an expensive replacement AGM battery is now unnecessary, a standard sealed lead acid battery is adequate, to reverse just reconnect sensor.
You will not get any regeneration as the ECU needs to know the SOC for thar to occur, me, all I wanted was rid of stop/start.
