Best tires for your Regal
Best replacement tire set you had already tried on your Regal?
  • Total voters
    114
One reason, no foam. Continental didn't have that cream filling ready in time for the car's US launch so early ones like mine went without. Also, not many high-speed curves on the roads I drive.
I drove mine primarily on straight smooth roads here in FL, foam filler never gave me any trouble. The rubber on the outside started to disintegrate. I posted pics here.
G-Max's are also XL (extra load rated) so with +1 sizing they have 320 lbs more load rating so tire is less stressed.
Another plus is they are pretty cheap on Tire Rack.
But not as cheap as my used like new OEM Conti's, since my red instrument TourX was early production it had non foam tires and autobahn speed capabilities.
Did you ever try to go above 132 MPH? My Sportback is also early production red needle and it doesn't go above 132 mph.
Yes, best tires according to your opinion. Those are summer tires if I remember correctly. Are you also in Florida? I try to stick to all-season since I may move up north again. Currently deciding between Conti PureContact LS and Michelin Primacy MXM4.
I’m a big fan of Yokohama Avid Ascend GTs but won’t know for sure whether these are better than my Contis until the contis wear out and make the swap. But tool with Yokes on all of my other vehicles.
Between the two I’d suggest the Conti PureContact LS. The Michelin Primacy MXM4 is generally an OE tire, which means a car manufacturer had it specced out for a certain vehicle, to hit certain targets (like rolling resistance for CAFE and cost). Drivers are generally happier with replacement tires, which tend to put more emphasis on performance drivers care about (like wet handling, tread life, and snow traction). The PureContact LS is a replacement tire (and a good one). A more comparable Michelin would be the Primacy Tour A/S. The Bridgestone Turanza QuietTrack is another good, premium all season touring tire. The Yokohamas mentioned above are well regarded also.
Not sure about limiter on non TourX
Regals.
Car and Driver`s roadtest of higher performance red instrument TourX, had top speeds in various gears. Said it was HP limited in top gear to 140 mph, but was faster in lower gears when running on a high speed oval.
I would tell you to stay away from the PureContact LS. After 7,000 miles, 2 of mine were horribly out of round from a tire construction issue. The ExtremeContacts that I had for 2,000 miles before the PureContacts had a similar issue.
Primacy Tour is also OEM on most new Cadillac models and I believe they are also good tires. I actually think getting *any* tires that come as OEM on any car is a good thing since one of the car makers validated these tires at some point. Sure, some OEM tires may not be good, but I would say Michelin is probably the best tire out there, although Premier were horrible on my car when I tried them. I had three new cars with Primacy MXM4 and they all drove great.
I primarily drive another vehicle during the winter. That's if I need to go out since I'm WFH. But I have driven in the snow once with them and they actually very good. My oem Contis were taken off at 38k when I bought 19"rims and tires. But they probably had another 1.5 years left on them. They had the foam on the interior. I thought they wore exceptionally well especially considering I did a NY to Vegas road trip and back two July's ago
Ah, so I’ll be. Didn’t realize it was OE on some vehicles now. And yeah, the Premier was a rare miss for Michelin, they’re generally pretty rock solid these days.
Oh, the foam...The OEM Conti's on our 2019 TourX with the foam didn't make it through a pothole-induced sidewall perforation (not the tire's fault),
but after a roadside plug in the tread to get me back home, the regional tire shop couldn't figure out how to do a better shop-plug where the foam was. At that point I ended up with 4 new decent tires with no foam. I don't notice any noise difference w/o the foam (another gimmick?)
What brand were the new formless tires?
Supposed to get up to 10 inches of wet snow today. Will be curious to see how the Goodyears my Sportback came with do in the snow.
  • Wow
Reactions: D2R
Looking like it's gonna be less than 10" but the tires did pretty well at acceleration and stopping. Turns were a little less grippy then expected.
Generals they had in the shop.. Gave 'em a little test in the Adirondacks over Thanksgiving. I like 'em.
That little trip was about 600 miles, including a few hundred on dry thruway, wet twisty's, sanded backroads, etc
  • Like
Reactions: L J
One thing I noticed with the Regal in the snow last night is the rear end really wanted to drift out of the turns. The only other AWD vehicles I've owned are Traverses and I don't get that to the same extent with them. Not sure if it's the weight difference or a difference in the type of AWD system.
Got to remember the Traverse is truly "slip and grip" - that AWD system has zero desire to have any sporting intent. If you take your Regal on a dry empty on-ramp (cloverleaf style) and get on the boost it will try to step the rear end out like a RWD vehicle.
Which is why I love it.
What do you mean by "step the rear end out"?
A little of topic, but does anyone know for sure if our wheels are lug centric or hub centric? I took an OEM lug out of my GS recently and it looked like it was a lug centric setup. The lug nut was very tapered and cone shaped.
I know a lot of other GM vehicles are lug centric wasn’t sure about ours.
I think he means the torque vectoring kicks in, but alas in snow or sand, I don’t think the torque vectoring will work very well. I for one don’t drive like Jeff Gordon, more like a grandpa, so whatever the car is doing doesn’t really affect me. On a different note I do have a set of Yokohama snow tires on 5x115 rims for my Chevy Volt, which happen to fit the TourX. The overall diameter of the wheel will be a little smaller so my speedo will be off, but if we ever get Snowageddon 3, I’ll be prepared. I bought these tires at the end of Snowageddon 2, and they did a fine job of warding off Snowageddon 3. I thought about selling them, but know full well that as soon as I sell them, the snow will come and I would wish I didn’t.
I guess another interpretation of “step the rear end out” could be mooning someone in public… 🙂
…almost the same as my statement of “my speedo will be off”
