x10003q
- Jun 1, 2012
- 2019 GS
Thanks. I will go look.Don't need 22.9 to have the clock in the instrument panel/cluster.
There is a setting to turn that on.
The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
I just looked. There is no sign of a clock anywhere near the speedo/DIC. The only clock is on the entertainment/nav screen.Thanks. I will go look.
I have the TourX, so I don't get the fancier 8 inch DIC.I just looked. There is no sign of a clock anywhere near the speedo/DIC. The only clock is on the entertainment/nav screen.
I have a 2019 GS.
Thanks for the info. My GS does not have this system.I have the TourX, so I don't get the fancier 8 inch DIC.
For my vehicle, I need to navigate to the far right side to go into Options menu.
Then choose Home Page Options.
Check the box next to Time.
Then move all the way back to the left side to go back to home page.
The clock would then display.
I am not sure if it is possible to get the clock on the 8 inch DIC. Never dealt with that before.
On the other hand, I still have 21.1 radio.
Edit:
Now that I have seen some video on the GS DIC, it appears to be the same as last gen Regal GS's cluster. From what I remember, it does not have an option to display the clock there.
Also, I wish you could see the cardinal direction somewhere if you are in CarPlay.I wish the DIC could display the outside temperature because when using Apple CarPlay, the outside temperature is not displayed on the infotainment screen.
I simply look at the clock and the location/direction of the sun on the sky.Also, I wish you could see the cardinal direction somewhere if you are in CarPlay.
GS for the win. I display the compass on my heads up display.Also, I wish you could see the cardinal direction somewhere if you are in CarPlay.
I think some reported having luck doing a system reset. Then set things back up the way you want again and hopefully you are good to go.Finally got the 22.9 update while in for LCA/upper strut mount replacement.
Upgrade alone didn't work, they also had to install a new SD card.
The good - speed limit sign in the DIC now works properly.
The bad - Android Auto disconnects itself about every 10 - 15 minutes. Was bulletproof before the update.
When my radio was replaced (becuase it wouldn't take the update) I have greyed out XM presets sometime. But it is only XM, not terrestrial or Iheart presets, and not all the XM ones. It's not hard to restore them, but I might try creating a new profile first before doing the reset.I think some reported having luck doing a system reset. Then set things back up the way you want again and hopefully you are good to go.
Is your speed sign working on 21.1?I have the TourX, so I don't get the fancier 8 inch DIC.
Edit:
My Tour X came back fixed today. It is now showing the speed limit properly.My 2018 White Needle Preferred went to the dealer for an update today, after updating to 22.9, the speed limit still has no value. And the nav cannot find the SD card anymore. I left the car to them to see what they can do.
IPC SOFTWARE WAS OUT OF DATE
LOOKED FOR BULLETINS AND FOUND 18248TO REPROGRAM IPC FOR IMCOMPLETE SOFTWARE IN IPC.
REPROGRAMMED IPC AND VERIFIED SPEED LIMIT WAS WORKING AFTER REPAIRS
Wait, so your one is the red needle. Which kind of radio does it have?My Tour X came back fixed today. It is now showing the speed limit properly.
On the receipt it says
No, it is white needle. With the Bose Sight and Sound Android based radio.Wait, so your one is the red needle. Which kind of radio does it have?
