Somebody Who Left
Junior Member
- Aug 5, 2016
- Northern Virginia
- 2012 Buick Regal GS 6MT
The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
Yeah, I took the bumper off, removed the HID assemblies, replaced them with the halogens, and plugged them directly up (the plug had to be inverted 180 degrees). Around 30 minutes if you've taken the bumper cover off before.
......I Thank GOD I don't have condensation in my light yet (83K), but when I do, I want to be prepared.
Hi, I ordered two different sets of LED bulbs, hoping to be able to get a working drivers side headlight for a lot less than $1200. After removing the existing HID bulb and looking at the wire that connected to it, and the connectors on the new H7 bulb, I see they do not match. It is clear that I don't know what I am doing.
I have attached pictures of the wire that went to my old HID bulb (does this come from the ballast?), of the old HID bulb, a view into the headlight assembly from the hole in the back, and of one of the new H7 bulbs I bought.
One of the H7 bulbs that I bought is shown in my attached pictures, and I bought it from here: (Combo H11 and H7 LED Headlight Bulbs Kit High Low Beam Fog Light 6000K 4pcs | eBay)
I looked for video tutorials, but the connections did not look the same as what I see on my 2012 Regal GS.
Do I need to buy some additional conversion kit?
Do I need to disconnect the other wire which goes into the back of the headlight assembly, closer to the middle of the car? If I do this, how will power get to the other light bulbs (fog lights and turn signals) that are also in that headlight assembly?
Any guidance will be appreciated - thanks.
Here's one that's 50% off and it includes both pairs of bulbs for the low beams and high beams for your 2012 Regal. It comes with a 5 year warranty so it should give you many years of reliable service.
9006 LED Headlight Kit Low Beam Bulbs Bright White 6500K Fanless Canbus 847256085791 | eBay
Find many great new & used options and get the best deals for 9006 LED Headlight Kit Low Beam Bulbs Bright White 6500K Fanless Canbus at the best online prices at eBay! Free shipping for many products!www.ebay.com
Keep in mind these bulbs will only fit the composite headlight assemblies, not the HID headlight assemblies on your car now.
I know the D1S HIDs are both High/Low beam (Single Focus Lens), but all I see are the LEDs are ONLY High or LOW beam ( for 4 bulb Halogen assemblies ), but not BOTH (Dual Voltage). Does the plug that goes into the Ballast, plug into the LED?
Hi, could you please explain exactly what you bought? Thanks.
Agreed. Good advice filing the formal complaint. Class action suit is warranted.Does everyone feel that there have been enough issues with the condensation/water getting inside our HID headlights for a recall? I do and I recommend everyone that has had this issue file a complaint here
File a Vehicle Safety Complaint | Safercar.gov | NHTSA
This a a huge safety concern that needs to be addressed and corrected by Buick/GM.
What are your thoughts?
1 set of Halogen Headlight Assemblies for the 2012 Regal - came with all bulbs installed:
Amazon.com: Headlights For 2011-2013 Buick Regal Pair Assembly Capa Halogen Type Depo GM2502353C GM2503353C: Automotive
I am having the same problem, took the car back 3x to get it fix and it still has the moisture in it and the guy said that's normal. How do you file a complaint and yes I think it should be recalled. My daughter in law has a 2012 and her's does the same thing. I also am having electrical issues where the radio and a/c shut off while driving.Does everyone feel that there have been enough issues with the condensation/water getting inside our HID headlights for a recall? I do and I recommend everyone that has had this issue file a complaint here
Thanks for the info. While that link showed out of stock by the time I went there today, I found this similar item and ordered it today:
Amazon.com: DEPO RLB BK REGAL 11-14 HL ASY HALOGEN LH (336-1123L-AS): Automotive
Buy DEPO RLB BK REGAL 11-14 HL ASY HALOGEN LH (336-1123L-AS): Headlight Assemblies - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
This drivers side headlight assembly arrived yesterday. We did a quick test (hooking it up electrically without installing it in its proper place), and all its electrical functions worked. The appearance of the stuff inside the headlight assembly is not identical to my HID original (this difference is to be expected - this replacement is not HID). Based on this successful test, I went ahead and ordered its matching passenger side headlight assembly. After it arrives, I will do the installation, and finally have two working headlights again.
