carsrmilife
- May 17, 2019
- Brighton, MI
- Regal TourX
The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
That's the plan, but the TourX does not have power or signal wires for the fans. So some more wiring needs to be done.
The wiring is done, I just need the feature enabled in the BCM I think.*disclosure* I'm a GM Engineer and I've done harness work in the past. I will try and find some harness blueprints and pin out guides to help with this. No promises, but I will try 🙂
It would have to be programmed also. I'm hoping White Automotive can help with that too.Have you tried swapping over the gauge cluster?
RoRi- two questions. Is there a link to the suspension springs? Are the rear seats a straight swap from the GS to the TourX?
RoRi,
What are your ride and handling impressions with the stiffer lowering springs? Since nobody sells sway bars, that might be the best option to improve cornering.
Rori,
I noticed that you changed you fender side running light from clear to smoked, is there a replacement for the bumper blinker from amber to clear or smoked?
I love it.I finished decladding the passenger side yesterday. If you are going to take your side skirts off be extremely careful to break as few of the clips as possible. I don't see any way to get them off without breaking a few, but I wasn't careful enough. GM does not sell them seperately from the rocker cover!!! I had to order a cover just to cannibalize the clips. Ugh
On the bright side I confirmed the Opel caps I have in stock fit our wheels. If anybody is looking for some I have them for $35 a set shipped.
