1500cc
- Jan 31, 2019
- Ontario
- 2018 Regal GS
I've never seen tire companies recommend such a thing. If you guys have a link handy, please do share it.
A couple of links:
From Michelin: Mixing Tires | Using Different Tires | Michelin US
When replacing two new tires instead of four, be sure that your new tires are the same size and tire type as your current tires, and that your dealer always installs the new tires on the rear axle of your vehicle.
From Tire Rack: https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=52
When tires are replaced in pairs...the new tires should always be installed on the rear axle and the partially worn tires moved to the front.
