AWD GM
- Jan 1, 2020
- East-central Pennsylvania
- 2018 GS
Thanks, i'll check it out.
Hey RoRi or anyone else who's lowered their car on the H&R springs, was that with stock shocks and struts or were those swapped out as well? I would really like a more sports tourer-like ride height so I'm gathering info on how to make that happen.
Thanks!
Good to know! That definitely makes things easier. Thanks!As far as I can tell, no aftermarket shocks have been released yet. And for what it's worth, I think I read a while back on online that H&R DE designed these springs to be used with the stock "Country Tourer" shocks.
@RoRi
Do you feel that the front shocks blow through the travel pretty quickly on moderate bumps like RR crossings and hit the stops. The ride is great with the H&R springs, but I feel the front shocks need more compression damping to keep it from bottoming on the stops.
Any thoughts on what you are feeling?
Nope, that's it. You only need the lines for the front.@RoRi,
I wanted to confirm with you the required parts for the Brembo brake swap.
Calipers
Rotors
Pads
Brake Lines
Dust Shields
Is there anything else I'm missing? Thanks!
@RoRi
I think there are some 19" Lacrosse wheels that would bolt on, if you're into that kind of thing.Same here on lowering all my cars. If we had just a bit stiffer damper it would be perfect. Handling is waaaaaay better lowered. Thanks for the quick reply.
Any hints on finding wheels that fit? It's a bit rough finding the right bolt pattern and offset in 19" wheels.
Where's the best place to get the H&R springs from? I saw an amazon listing for them straight from H&R but $214 + 63 shipping seems steep when I saw them a few months ago for 188 or so.
ajusa.com used to have them but apparently they're no longer on the site...I saw a listing on Ebay for $290+/- shipped. I couldn't find anywhere in the states to purchase.
