Yes, they clear
Thanks for the reply. Do you know for sure if the mounting points are the same between the tourx and GS? I’m just wondering if the rotor size/position difference might have the caliper in a different spot on the GS versus the tourx.
The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
Yes, they clear
According to this websiteThanks for the reply. Do you know for sure if the mounting points are the same between the tourx and GS? I’m just wondering if the rotor size/position difference might have the caliper in a different spot on the GS versus the tourx.
Yes, the bumper cover has to be removed. It's not difficult. There's only one harness plug to unplug for the foglights and impact sensors. The hardest part is removing the old grill; there's about 2 dozen little clips that all have to be released.
Your wagon is kick ass man. New owner as of today and I have one quick question. I do not have ACC. Is there an Opel or Vauxhall (prefer Opel) front emblem that can replace the Buick emblem without having to replace the whole grill?
Do it correctly, or don't do it at all. I've seen people plop various badges over the Buick grill and it looks like complete crap IMO.
buickforums.com
Fairly easily, you'll have to remove the plastic plate which covers the space between the front grille and the radiator--7 plastic rivets (use a small bladed screwdriver) and then you can see the back of the Buick emblem (and the top two tab clips that hold it on, the bottom two you can feel for). Press the top two tabs and push them towards the front, then likewise the bottom two & the emblem should come off.
[/URL]
What is this exactly?!Hey, I have a Sports Tourer too...
View attachment 16248View attachment 16249View attachment 16250
It's just a bit smaller.
They were showing photos of the 1:43 die cast model car.What is this exactly?!
I'm not sure if you can answer this, RoRI, but do you have any clue if it is possible to easily add a memory seat module to the standard Essence seats? Is the wiring there, ready to be hooked up? What sort of modifications would be required to make it so?
I have an Essence with S&S but not DC1. If I were to source a seat with memory seat (including harness) would it bolt in? How would remotes work, since I don't have a 1 and 2? Since personalized infotainment is also related to this, would I need my BCM flashed?No, you couldn't easily add just the memory module to the seats. The harnesses are different, there's no power for the memory module, and the BCM won't recognize it anyways.
Mine are a light 23LbsDoes anyone know what those Wheels Weigh ?
Those wheels look great! I'm curious though... what is that strip going across the center of your doors? Is that something you added?Mine are a light 23Lbs
Hi RoRi, thanks for walking us all through your project you've helped us all out a ton! I saw on one post that you had diagrams for the seat harness plug pins... do you mind sharing where you sourced those diagrams? I hope to find diagrams for the connection to the headlights. My 2018 regal came with halogen and I have led replacements but my current harness needs three more pins to match the led headlights but I need to know what type of inputs they should be... I appreciate any help you can give.
P.S. Maybe DarthAvocado can help 🙂View attachment 20601
