The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
I definitely remember removing the hubs in the rear. I can't remember the fronts though, but I think so.
I am curious as well. Will our dampers survive on this setup? Is the corner loading similar enough so that the spring rates will be effective for the Regal? Has anyone cross referenced with the Opel parts bin?For those looking to lower their cars, at least the FWD Sportbacks with the 4 link rear suspension, not sure about the AWD Sportbacks and TourX with the 5 link rear, Chevrolet sells a lowering kit for the Malibu which is the same E2XX architecture and same basic layout as the Regals. I am wondering if their lowering kit would fit. From knowing what we know about the architecture and similarities and the RPO codes, it seems it would.
Malibu RPO Suspension Codes:
Regal RPO Suspension Codes:
Malibu Lowering Kit:
Could you ask if they have a stiffer spring than keeps TourX ride height as is?Have you looked at the H&R springs in detail? There are 8 different versions for our cars. I suspect that it relates to weight distribution based on engines, transmissions and other options. The Opel packages are not quite the same as ours so I have an email into H&R now to dive a little deeper.
The only setup that may work with the TourX is below and they lower 35mm.
You can go to this site and search. www.h-r.com
Or check out this info nice article: Opel Insignia with Esprit - H&R components for the Rüsselsheimer - tuningblog.eu
There is additional info on the version 8 if you look a little deeper.
I ordered a different one from Europe, took a lot of fabbing, but still doesnt look like it really belongs. but i like it more than not having it. It's called the Variox lip. It was a bit of work, cutting, sanding, etc.Looks good, I wonder if they have a version that fits the stock TourX bumper.
Off topic, but I follow you on insta. @saintworksI ordered a different one from Europe, took a lot of fabbing, but still doesnt look like it really belongs. but i like it more than not having it. It's called the Variox lip. It was a bit of work, cutting, sanding, etc.
Very nice. Where did you get the yellow fog lights?I ordered a different one from Europe, took a lot of fabbing, but still doesnt look like it really belongs. but i like it more than not having it. It's called the Variox lip. It was a bit of work, cutting, sanding, etc.
I was gonna do that but I really wanted the permanent full yellow look as well.I used to have the Lamin-X yellow tint on one of my older car's fogs.
Since no one makes the yellow tint on our TourX, I just swapped the bulb to a yellow one instead.
