WOW.
That looks incredible!
Are those 20" RS wheels?
For those looking to lower their cars, at least the FWD Sportbacks with the 4 link rear suspension, not sure about the AWD Sportbacks and TourX with the 5 link rear, Chevrolet sells a lowering kit for the Malibu which is the same E2XX architecture and same basic layout as the Regals. I am wondering if their lowering kit would fit. From knowing what we know about the architecture and similarities and the RPO codes, it seems it would.
Malibu RPO Suspension Codes:
Regal RPO Suspension Codes:
Malibu Lowering Kit:
I am curious as well. Will our dampers survive on this setup? Is the corner loading similar enough so that the spring rates will be effective for the Regal? Has anyone cross referenced with the Opel parts bin?
So the corner loading comment got me thinking. I did some research on the Regal and Malibu curb weights, and they are quite different.
Malibu seems to be 3,100 to 3,300 lbs.
Regal and TourX are 3,700 to 4,300 lbs.
Have you looked at the H&R springs in detail? There are 8 different versions for our cars. I suspect that it relates to weight distribution based on engines, transmissions and other options. The Opel packages are not quite the same as ours so I have an email into H&R now to dive a little deeper.
Could you ask if they have a stiffer spring than keeps TourX ride height as is?
Interesting Build. Apart from the Calais / Calais V, we have over here what is known as the RS-V. This one has a few subtle mods (namely springs and 20 inch rims).. I does lack some features such as HUD, Leather, Sunroof and Digital dash (standard on the Calais-V) but looks the business...
Looks good, I wonder if they have a version that fits the stock TourX bumper.
I ordered a different one from Europe, took a lot of fabbing, but still doesnt look like it really belongs. but i like it more than not having it. It's called the Variox lip. It was a bit of work, cutting, sanding, etc.
Off topic, but I follow you on insta. @saintworks
Very nice. Where did you get the yellow fog lights?
I used to have the Lamin-X yellow tint on one of my older car's fogs.
Since no one makes the yellow tint on our TourX, I just swapped the bulb to a yellow one instead.
I was gonna do that but I really wanted the permanent full yellow look as well.
  • Like
Reactions: D2R
I took delivery of a brand new GS last month. OMG what a car. It is all about the active suspension. It may be impossible with all the electronics but if you could swap those onto your build it would change everything. Standard setting is under damped and prone to bottoming. Sport mode takes care of any bottoming problems and is still smooth enough to drink your coffee. GS mode is the magic carpet. It flattens right out on the corners and tweaks the handling as you go so you feel like a genius in the corners.
My problem is the seat is crippling me. It is too radical for my back. Do you think the seats from an Essence Sportback would plug right into my GS harness okay with no other modifications? I would be trading down in technology so it might work. Thanks for any advice about the seat.
